Small Boats Outside of the Harbor
As others have said - the weather forecast is important. I am from California, when I lived there all of my boats were under 20 feet. I often left the harbor and sailed much of the day 'outside' - and over to Catalina, round Anacapa and so on. Southern California in summer is pretty benign most of the time, but still, like everywhere, it is a good idea to watch the forecasts.Ross, a front should show up on a forecast - if it is coming, don't go out. In Fl, thunderstorms are probably more of a risk as they can build up locally. Again, forecasts are the best defense, as is choosing the best time of day to go out, mornings work well here in Colorado to miss the thunderstorms. Being 5 miles off shore in a dead calm is not likely to be much of a problem by itself - a 22' boat should have a motor. Oars and an inflatable boat are not bad ideas.Curt needs to learn the local weather, and about the gulf stream and weather effects upon it, then pick his times to go sailing. With a good conservative weather eye and good local knowledge, the boat will do fine. I'd stay well away from small craft warnings, and any forecast risk of squalls or thunderstorms. Know the local area and where to duck back inside - carry a good anchor so you can anchor when back inside the ICW if still a ways from home and you have to ride it out for a while.Do people who sail bigger boats think that every race run by J22/24's, Santana 20's and U20's, Catalina/Capri 22's an so on is done in a harbor?OC
