Docklines as jacklines on h27
We attach 25' docklines to each of our two bow and stern cleats. On departing the dock, while motoring out of the marina, we tie the docklines that were in use into a jackline. First we put a bowline loop in the end of the bow line around a bight (loop) of the stern line. we then haul on the stern line around the stern cleat to tension the line, and tie it off on the cleat. The unused docklines on the other side are already made up in this way. This keeps the docklines on deck, but out of the way while underway.When returning to port, we just undo the lines as required, once we are out of the seaway. At anchor/mooring, they stay in place.While the round lines could be a tripping hazard, they do line right against the cabin on our '77 h27, and have not caused a problem yet. The Admiral comments that we are always mangaing the tether along the jackline when moving along it, so it's unlikely to step on it. Our decks have good width (the shrouds attach outboard along the toerail), and against the cabin roof is not a natural foot placement.The bowline knot makes a natural stop against being swept too far aft. It's clear with our 6 foot tethers that a fall over the lifelines would still leave one dragging in the water. I have hooked on to the jackline on the opposite side to prevent this while single handing in five footers. In any case, overboard and attached is a whole lot better than overboard and adrift! By the way, the same system worked just fine on the modern h340 we chartered this summer in the North Channel.Our standard MOB recovery is to move the vang (on snap shackles) to the end of the boom, and attach it to the harness, or lifesling to provide a 4 fold advantage in lifting one of us back onboard.We also have a pad eye in the cockpit to clip on there. You can get outside the lifelines, but not in the water from this point, and we spend 95% of our heavy weather time hooked up there. (Of course, the other 5% is the most hazardous time when going forward.)DavidLady Lillie
