SafeFS30 - installation on a Passage 42 - Location to install?
Jan 1, 2014
181
Hunter 42 Upper Chesapeake
Any suggestions on where to install 2 - ProSafe 30 Amp Galvanic Isolator on a Hunter Passage 42
JamesG161
Feb 14, 2014
7,815
Hunter 430 Waveland, MS
I am fairly confident that Hunter Installed a similar device on every boat they made that has AC shore power.
Mine is called "Zinc Saver" and is located behind the AC Breaker panel.
Just follow your main AC - 3 pole breaker's green wire, aft toward the Boats AC Inlet plug.
Look for the space used for your old, Isolator.
If no old Isolator there, there should be space provided,
Hope you have space for 2 of them, but they do make one single unit that is 50 amp or dual 30 amps capacity.
Jim...
Dec 25, 2000
5,945
Hi Keith, your boat likely has one already. Jim located his and is in the same location on our boat; behind the power panel.
Jan 1, 2014
181
The panel above the chart table? Seems like it should be closer to where the power comes
Onto the boat
Apr 12, 2007
206
Hunter 420 Herrington Harbor South
2005 420 ISOs are located under the floorboards between electrical panel and cabinet/nav station. Next panel forward are the house batteries.
  • Helpful
Likes: JamesG161
