Keel Filler
Ken: When you helped your friend with his keel, did you use anything to fill or smooth the irregularities? In a reply a few weeks ago, someone recommended coating a keel with VC-TAR. I plan on doing that next spring, but my keel could certainly be a little smoother. Also, on one side, the casting doesn't perfectly match the other side, and it would be nice if I built this irregularity up with some kind of filler. There are also a few pits that I would like to fill. Do you have any recommendations? I just can't see coating the keel without first improving it's shape a little. Normally, I just scrape everything that's loose off of the surface of the keel, then paint it with ACE Hardware primer, then a coat of their oil base paint, (both much better than Rustoleum), then a coat of bottom paint. This usually looks OK when we pull the boat out of the water at the end of the summer, but by the spring, much of the paint has flaked off, pushed off by rust. I know that if I could seal the cast iron, the bottom paint would stick for years, (the way that it does to the hull), and I wouldn't have to lift the boat up and paint the keel every year. Thanks, Aldo
