Sabre 34 MKI installation of Code Zero Sail??
Jan 27, 2023
3
Sabre 34 MKI Sabre 34 MKI Atlantic City
As title says, wondering if anybody has experience installing a Code Zero sail on a Sabre 34?
Welcome to the SBO Forum
What type of system are you thinking.
  1. Just the sail with a snuffer
  2. Torsion roller reefing sail
Different design and equipment needs.
Your mast and bow are a basic Masthead rigged sloop.
Jan 27, 2023
3
Understood about masthead rig. Torsion roller reefing sail to eliminate/reduce greatly foredeck work.
Ok.
You need an attachement strong point on the bow, or a sprit to carry the task of the sail.
What des your bow look like. Pictures are helpful. Frame the image vertical looking down at the bow from about three feet back from the bow to out over the bow beyond any pulpit.
Then an image from the side covering about the same area. And a front on image.
This is so how to rig the sprit can be determined. Also you need to identify if the sprit needs a bob stay.
Jan 27, 2023
3
At the moment I'm away from the boat although the sprit idea is going to be a necessity. Many thanks for your thoughts so far. It may be a while before I get to the boat to take photos but I will keep your correspondence to pick up on this later. Ultimately, I am getting the sense that this may be a costly project, right?
If money is no object you can look at the Selden retractable sprits. Nice
Yes money is an issue for a Code Zero.
What type of sailing do you plan on doing? I found an Asymmetrical to fit my more casual cruising. It allows me to sail as high as about 70º and as deep as 170º with the sweet spot at 110º-160º off the wind. I am not racing. I just want to sail even in a light breeze.
Welcome to SBO. The best place to ask this question is over on SabreSailboat groups.io Group. About 1000 Sabre owners, past owners, and wanna be owners are there and many of them have added Code Zero and Asyms to their boats.
