pro's and con's-245
have had a 245 since 1985. have really enjoyed the boat. i sail in tampa bay which is quite shallow in many areas and being a centerboarder the boat can go where many fixed keels fear to tread. it is a very reactive boat and you have to stay on top of it as she is quite tender, but has all the sail controls you would want. a lead keel on this size boat is also a plus. heads always turn when the boat passes as her lines are beautiful.i have had some blister problems and used interlux barrier coat.almost everyone who has owned a seidelman has found that the backing on the interior has turned to powder and has had to do something about it. i removed mine and just painted the interior. check the chain plates where they attach inside the boat as they often leak and the attachment points can rotif you have a chance to haul the boat examine the centerboard pivot screw. mine had almost corroded through before i replaced it. not vey expensive if you catch it in time, only the cost of a stainless steel bolt.also the outboard motor mount needs to be re-inforced or stern will oilcandeck to hull joint is one of the best.the boat is transportable, but not easily trailerable. let me know if you have any other ?'spaul/
