S2 Steering cables
56
Cape Dory 30 Ketch Kemah, Texas
I just finished installing the pedestal and new cables. The old pulley plate totally fell apart under the deck. I have installed new cables but they are not lining up to the rudder platter wheel. The cable needs to angle down about two inches for the angle to be correct. Is there a solution for this? I thought of adding two pulleys just forward of the rudder to push the cables down slightly. I have raised the rudder wheel as high as it will go. Any ideas would be appreciated. After this endeavor I am pulling the engine for a rebuild unless someone has a good deal on a Yanmar single cylinder diesel.
