Does anyone know the name of the S2 logo font (does it even have a name)? No, I don't need new S2 decals, but I would like to put the name of my new boat on the transom in the same general style. Thanks.
Don't know that the S2 font has a name (I have never seen it anywhere else on anything). You may have to get an illustrator to do up the other letters which you need in the style of the logo. Does sound like a neat idea. Let all of us know if you have any success in this.
Then put the picture on your copier and blow it up to figure out the size you want. Find a local firm that makes vinyl lettering and have them cut it for you. I bet it is no problem for them.
I found a font at dafont.com that is *pretty* close for the letters that I need for my transom, although other letters are pretty iffy. The font is called "TR Heavy." Might work for some of you, depending on the letters/numbers you might use (e.g., the number "2" isn't right *at all*, but I don't need it--it simply isn't the S2 number "2"). Thanks for your input!
