I probably should have posted this last year. When I bought my 9.2A several years ago the door to the head was misaligned, the hinge side had sagged. I let it go for awhile and then started investigating. The floor at the base of the compression post at the forward side of the head was also sagged. I removed the holding tank and cut an access hole to get under the post. The post was sitting only on the floor, there was no support underneath. All of the loads from the mast came down to the floor and was pushing it down.
I removed the door, loosened the rigging and used a house jack to raise the hinge side of the door to bring it back up to where is should be. I then used a block of teak and some teak shims to support between the floor and the hull and restored the holding tank. The head door now closes almost properly and the floor is properly flat. Has anyone else seen this problem?
