S2 9.2A Bimini
RussB
Nov 3, 2007
42
S2 9.2A Bay City MI
I have a 1979 9.2A with stern transom mounted traveler. I would like to add a bimini but have no idea how to extend it far enough aft to well shade the helmsman and not hinder the main sheet. Does anyone know of or have a good solution to this issue?
Thanks,
Russ
Mar 29, 2008
187
s2 9.2C NJ
I have a 9.2c. Same Prolbem. Could you have two biminis? A small one behind the traveler? I gave up on a bimini for this reason.
Mar 8, 2008
41
S2 30 9.2A Jax
With the stern traveler, there is no perfect solution. I've attached a photo to show how our dodger and bimini look. We went as far aft as possible, but had to stop at the mainsheet. It's a good set up, but does not cover the helm.
Rick
187
s2 9.2C NJ
Oh, I see the 9.2A traveler is way back there. It wouldn't make sense to do a bimini behind the traveler. How's the headroom under the bimini?
41
S2 30 9.2A Jax
Under the bimini, it's about 6 feet, 4 inches and under the dodger, about 6 feet, 1 inch. That's about the most you can get on a 9.2A before the boom becomes an issue under sail.
Rick
BobM
Jun 10, 2004
3,269
S2 9.2A Winthrop, MA
http://www.thefedorastore.com/Solarweave-Treated-Cotton-Mesh-Safari-Hat-p/spf4.htm
The hat is very comfortable and water resistant.
The aft traveler is definitely a challenge for those who want a bimini. I looked into the Mantis shade as an option, but it can't hack being used under sail. Perhaps if you bought one and replaced the shade with a mesh or modified it to have some flaps that would open to release pressure (like on a patio umbrella).
http://www.pro-techt.com/catalog.cfm
In any case, anything that doesn't interfere with the traveler will have to fit aft of the boom and be high enough to clear the main sheet. Perhaps a variation on this.
I don't know how much protection it would truly offer.
RussB
Nov 3, 2007
42
S2 9.2A Bay City MI
Thanks for the feed back.
I am considering having the stern rail modified to allow more step-through to the swim ladder. Perhaps I could have attachments for a small bimini added to the stern rail.
Thinking about my boat is sure helping the winter go by.
BobM
Jun 10, 2004
3,269
bimini
Now you have me thinking about a bimini. I think a small one mounted at the top of the rail using those strapless holding arms sounds nice. However, I'd want to be able to close it easily, as sometimes I like to stand at the stern rail and enjoy the view. Therefore I think I would like the closed bimini to sit aft over the stern rail out of the way a little.
I don't know if you have seen them, but strapless seems the way to go in my opinion....but perhaps not if you can't close it easily.
http://www.geminicanvas.com/conversionkit.htm
H
Houston Jim
Bimini works fine on 9.2A
My bimini is about 7 or 8 feet long, extending from the main sheet to halfway over the hatchway opening. It has over 6 feet of clearance under it. The helmsperson is shaded or not, depending on the sun angle. I like to stand on the seat and look over the bimini to see the sail trim. Works well and I could not sail in Texas without a bimini.
