S2 9.2 C holding tank placement
MMcD
Oct 23, 2014
11
S2 9.2C Great Sacandaga Lake
I am looking to remove an Electa San system and install a holding tank and pump out. Where is the holding tank installed on the S2 9.2C? Does anyone have some photos or suggestion on installation?
Sep 15, 2009
6,244
S2 9.2a Fairhope Al
i am not familiar with the 9.2c only the 9.2a.....there was no holding tank in mine only electa san and overboard discharge ...i put a twenty gallon one under the settee next to the bulkhead of the head ...you may have to look around and find a locker space that will hold a tank...if i ever get on a 9.2c i will look for a space so i can recommend a place...sorry i was probably no help at all
Mar 11, 2013
57
S2 9.2 Port Washington, WI
I also have a 9.1 Aft cabin S2 and my holding tank is under the port side berth in the main cabin.
Mine leaked and I replaced it (tanks come in a myriad of sizes/shapes). The main thing I found out (the hard way) is that you must use "impermeable to gas" hoses. Don't simply buy hoses at Walmart and expect no odors. Odors penetrate most hose walls so you need to buy gas impermeable hoses....or expect odors continuously.
If you need help in finding a tank, send me a not (pappaboat@gmail.com) and I'll get you a contact.
Skippie
