RV Air Conditioner
Benny
"Caribe" is our Hunter 27 Cherubini. Here in Florida you need AC cooling 8 months out of the year. For the longest time I have had the idea of installing an RV Air Conditioner on the cabin hatch opening behind the mast. The unit in question is a 13.5 BTU weighing 90 pounds and standing 13" tall. The required opening is 14" X 14" while the hatch opening is approximately 17" X 17". I have seen various boats with this set up but I'm wondering what the negatives may be. I would like for someone who has actually installed one of this units in a crusing boat to comment on it. I,m concerned with forward visibility, weather sealing, raising center of gravity, condensation drainage and stains. Would a frame have to be built to shrink the hatch opening? Would I have to drill through the cabin top and the cabin liner?Would this be a virtual permanent installation which would be costly to reverse if the unit breaks or I decide to take it out. I'm currently running a 5,200 BTU small window unit wich fits into a companionway board. We run a Honda 2000EU at anchor and it is very adequate but climbing over the AC unit to get in and out is annoying the admiral. It stores in the storm bunk. The RV unit in question with a heat strip and shipping costs is Approximately $525. This is a lot less than the carry-ons and the inboard units. Portable air conditioners have to be vented to the outside and are heavy to move and just as expensive. Comments and suggestions would be appreciated.
Jun 5, 2004
242
None None Greater Cincinnati
RV AC
Lot of people use them. They work better than the carry-on marine units and the price is right. I don't like the way they look, but then my boat came with a water-cooled unit installed.
Bob
Try the Heir Unit
We found an excellent solution to cool our Catalina 30 in Georgia you may want to consider. We came across (at Target of all places) the 9,000 BTU Heir portable AC unit that cames on wheels, is very compact and has excellent features like; evaporative system with no condensation discharge and a 10 foot expandable flexhose that vented out the heat (thru one of our side ports). It fit snuggly in the "V" of our V-berth. It was only $399.00 and worth every penny. When the fall arrives we will put it back in the box and use it again next year. Something to consider to avoid cutting holes in your boat, meesing with dripping water and ackward hatch configurations. By the way we saw 10,000 BTU units of a different make at Pep Boys! Bob
