HUH?
I don't quite understand about your 2 weeks in salt water. Do you mean the boat was under salt water for 2 weeks due to a sinking? or do you mean you were sailing in salt water?I assume you were sailing or moored in salt water. Your stanchions should not be getting pinhole rust spots so quickly. If it is, then it sure is not SS.Sure sounds a bit strange. As for removing the rust, rubbing compond works fine, so does Bar Keepers Friend. But, if rusts is starting after only 2 weeks, Hmmmmm.... Now, if rust starts on SS stanchions after 10-15 years......How new are these stanchions and what are they made of?
