Jeff Talbot
In the process of buying a 1988 - 33.5. The survey was just done and it noted a pin hole with a rust line below it located 3/4 of the way down the port side of the rudfder just aft of the post. Apparently these rudders, built by "Al Walker Foam", have a stailess post welded to "mild-steel" strengtheners and filled with foam.Well I am concerned that the rust is extensive inside the rudder.Any stories/ideas/advise would be appreciated.Also all five thru-hull fuittings are jiggly and lose to the point that they leak.Otherwise no de-lkam in the decks or blisters in the hull.
