Rust between hull and keel 84 25.5
Scott Colimore
I pulled my boat and there was a rust line between were the hull and keel meet. What is the remedy or repair for this problem? The boat has a barrier coat but this has bleed through.
Dec 2, 1999
15,184
barrier coat may not help the rust.
Scott: The barrier coat may not help the rust. The first thing is the barrier coat is probably not applied in the area between the hull and the top of the keel. There have been numerous posts over the last few years on this issue. If the rest of the keel is not rusting, you may be able to blow out the area with air and then make sure it is completely dry. Then you can either use some fiberglass and fairing material to completely seal the joint. If you do not want to go to all this trouble, just try recaulking the joint and see that lasts. This is a fairly common problem on a cast iron keel boat.
