Running Wire Through Stainless Stern Rail
Tim
I need to run a gps antenna wire from my pedastal, underneath, and then up the stern rail. Any advice on how to best access the stern rail? Should I just drill from the inside up through where the mounting screws are? Or physically remove the rail and drill outside in?
Ray T
wire through the rail
Tim, This is one of those times when there is more than one way to skin a cat. My preference would be to drill up in the center of the bolt pattern. I always believe the simplest way consistent with a good job is the way to go. If you don't need to reseal where the rail meets the deck, start drilling. Ray T
Mar 23, 2008
66
Hunter 26.5 Urbanna, Va.
Remove the rail
That way there is no exposed wire down where footsies lurk.
