Torsten
Hi again, as said before we learn as we go along. Here is what happened: The water tanks had antifreeze in them so the surveyor suggested a flush. We turned on water pressure, opened the fawcett and water came out . We did not touch anything else like a valve or so. Did that drain out the tanks or just the lines ?Anyways, when the running water stopped I opened the water intake on deck and started filling the tanks. The whole time the water pressure was on , the pump was running and the fawcett was open (my thinking being that a straight run through would flush out the tanks best). Well ,the tanks filled up but no water ever came out. Any idea why? The tank under the starboard settee is under lot of pressure, when openening the black thing on top water pressures out immidiately. OK , everyone confused now ? We are , what could it be ?Thanks, Torsten
