I've recently purchased a Hunter 28.5. The Mast is currently set up to route up to 4 lines inside the mast, with only one, the mainsheet halyard currently running inside the mast. I'm guessing who ever had the boat previously had issues and re-ran some of the lines outside of the mast.
I'm thinking the topping lift and the jib halyard could have been run inside the mast at one time. The boat has a self furling jib that line is not needed so the jib halyard is not need. The topping lift is there but is not running internally inside the mast.
My question is what lines came from the factory running inside the mast, and what problems might I have if I try to re-run the lines through the mast?
