Running New Wiring for the Bow Light
194
Macgregor 26D Calif. Delta
I am going to need to run new wiring my bow light. The old is rusting out. It seems very tight. Have any of you replaced this wiring? I'm afraid that running new wire may be next to impossible. Anyone successfully done this?
Dec 29, 2005
8
- - Terrebonne, or
bow light wire
i replaced all the wire in my 82 Mac 25. To replace the bow light wire I soldered the new onto the old at the fixture and then pulled on the old from inside the boat. This pulled the new wire through the bow pulpit.
Jul 7, 2004
8,497
Hunter 30T Cheney, KS
marine grade wire
Be sure to use wire suitable for the marine environment. It should be finely stranded tinned copper conductor wire. Check out the chart for sizing
May 11, 2006
13
- - Mystic Islands, NJ
There is no trick
You do not state which boat you have but from your post I assume it is an S. I got a 100ft reel of 14 gauge marine wire from boatfix for ~$60 and that was enough to rewire the whole boat. The only problem was the bow light and stern lights. Like you said the wires are pinched between the three hull sections. There is nothing you can really do. I ran three new lines to the stern (pump, running and anchor light) and ended up splicing into the existing bow wire as high up as possible. I used the crimp connectors but got the ones that are filled with wax and use shrink tubing. So when you heat them they seal water tight. I guess if you want you can run a new line to the bow light after drilling holes through the inner hull but I did not bother. I like how the newer S's are run with the light in the bow railing, mine is on the hull... So just do any way you can. There is no trick. good luck, mark
