Here is how I do it.
I also have a '81 H33 here in Rochester, NY. When I haul in the fall, I disconnect the hose to the water pump on the Yanmar. I then connect 3-foot hose to the water pump, and the other end in a 50-50 mix of anti freeze. I run that through the engine to winterize.In the spring before launch, I use a bucket, set it on the floor in the head, run a water hose from the water system in the yard to the bucket. I place the hose from the water pump in the bucket, start the engine and let it run for a minute, then shut it down. This circulates fresh water though the engine. By the way, the antifreeze I use is the type that is supposed to be environmentally safe.If you had the yard winterize your engine, you could still connect a hose to the water pump and run water through the engine. This would also be a good time to check or replace the impeller on the water pump. That is an easy task by taking off both hoses, two bolts, and taking it right off the engine. Cost of Yanmar impeller and gasket about $12.You could probably also run the engine for a short time without water. Just not too long so that it doesn't overheat. This may not be the best thing for your water pump though. Maybe some others have advice on that.Ken Palmer, S/V Liberty
