Scott Wilson
didn't find anything specific to my boat. Mine is an '85 with cabin top traveler mounted on a raised base ( so the companionway hatch can slide under and through ). Halyards (3) are on two mast winches. The vang doesn't run to the cockpit either. Even the traveler trim requires reaching through the unzipped bottom of the dodger. The mainsheet winch is cabin top port side aft of the quarterberth hatch and was mounted on a raised base so the hatch could open a couple of inches with the sheet on the winch. I want to run halyards/vang back to cockpit, probably going through/under the traveler mount( drill holes) and running over the top of the quarterberth cabin top hatch, in such a manner that the hatch would then be non-opening. I think I have to have the rope clutches mounted aft of the hatch not forward. I figure that there is enough ventalation into the quarterberth through the cockpit hatch below the shallow port side locker. . I could run the rigging over the galley cabin top hatch, but I figure I want to keep that hatch operable to vent the big pot of Dungeness crab that sometimes appears on the stove. Not wanting to reinvent anything, how have all you long-time 37C owners done this project? Thanks for past responses on other issues. P.S. Currently, its breezy and not too wet in Seattle and you can sail with a view of snow-capped mountains. So,
