The running lights on the bow of my Catalina C 30 are not working. They are working on the stern and I checked for power at the fuse switch. I cut about 2 inches off the wires in the anchor compartment and hooked up a tester, but I have no power up front. Wires seem to be a bit corroded even with 2 inches cut away as they were under water due to the drain in the anchor compartment being plugged.
Does anyone know if the bow running lights are connected to the anchor light on the top of the mast? This was rewired recently, but it's the only think I can think of as to why there is no power.
If anyone has any suggestions, please let me know. This looks like a tricky wire to re-run as it runs right into the fiberglass in the anchor compartment into the body of the boat. I would have to rerun the wire through the molding in the V berth and drill a hole in the anchor compartment which I am not all that inclined to do.
