The steaming light on my 89 c -22 has been out since purchase three years ago. Now with the mast unstepped I was able to determine that the fixture and light actually work well. I took up the four prong deck plug and replaced it snce it was cracked but alas - I have no juice on one of the wires( steaming light )which is on the aft starbd side of the plug. Four red wires are fed thru the compression post in a common sheath. Pulled the electrical panel and found that the "Running Lights" looks like it turns on the mast steaming, bow and stern lights. That creates two questions for those of you brave enough to reply. 1) Does this mean that any time an 89 C - 22 has its "running lights" turned on it displays the steaming light at the mast? ie: it is incorrect to sail at nite with that arrangement strictly speaking( OK, I Know that if it's dark I'll probably motoring like hell to get home anyways - but what if?...) and question 2 - where do I start looking for a break or short in that line?
