Roger
I need to rewire the running lights wiring on my Hunter31. As installed, it is through the bow pulpit piping. The wires there originally weren't complete runs but spliced-together, which is where the wire failed and why, alas, I can't pull the new wire through by tugging on the old. They broke.The pulpit tubes are now empty, and I am about to drill a hole in the top of the pulpit's T to feed the wire first down to the light, and then over to the end of the puplit where the wiring then exits the tubing to pass through the hull.I have tried the vacuum cleaner-fishing line approach to sucking through a feeder line, and that wouldn't seem to work unless one had a jet engine doing the sucking.Any suggestions before I drill? Even though I can reseal the hole, one hates to bore through stainless.Roger
