Josh
In looking at making my 22 more one handed, I have decided to try to bring the haylards back to the cockpit. I liked how Paul Palmer did it in the photo forum article 'Lines aft on O'Day 25'. After examining my 22 though, I doubt that I could get the lines through the area between the teak slide and handrail the way he has.The way that the 22 I have was rigged, I have a haylard coming down each side of the mast. I was thinking of running them down to the sides of the deck and running them back along side the jib sheets. My question is has anyone tried anything similar? Any ideas? If I start mounting hardware to the deck, how do I go about putting backing plates to the blocks? Looking at some of the items that already are mounted, some come through both sides of the deck and are bolted down inside the cabin. Others have had holes drilled through the cockpit fiberglass and the plywood behind, only having a nut and the fiberglass on the otherside holding them to the deck. Obviously this is a bad system, and is the reason why I'm going to remove the life lines.If I drill through the deck into the cabin, and put a stainless backing plate, what kind of compression should I expect? Would I be better cutting the cabin side out, removing the plywood and putting the backing plate against the topside fiberglass directy? I think that doing it through the entire assembly would be the strongest. How strong does this setup need to be? I have yet to experience this, so my thoughts are still just that!Any suggestions?Thanks,Josh
