Hey Folks,What is the wisdom on running a diesel engine (Yanmar 3jh2) at the dock under load, i.e., with docklines restraining, to get some operating temperature running time? With no load, I believe the engine will never get to operating temperature. Not sure it will with a dockline load either but better than no load.I have done this up to 2000 rpm (max 3600 rpm) for ten minutes without separating docklines or dock so far.Also, an idea is running in reverse since it is inefficient in terms of propelling power but efficient in terms of loading the engine.Thanks for you thoughts.Peter
