Running Backstays
Alan
Jun 2, 2004
4,174
Hunter 35.5 LI, NY
Has anyone installed running backstays on their H26.5? I'm thinking of buying one of these boats and the first thing it will need is runners for better upwind performance. How did you configure them and what did you use?
Jul 19, 2007
156
Hunter 26 Brookville Indiana
English anyone
Been sailing for 15 years. 16 foot day sailors to my present h26. Have not been around too many "hard core" types. If you dumb down the jargon a little bit I might lean a few things and, remarkably, may even contribute. Or not. Regards.
Alan
Jun 2, 2004
4,174
Hunter 35.5 LI, NY
Mergatroid
I thought I was speaking perfectly clear English. If you have a question or something to contribute you are more than welcome to join in or ask. To try and anticipate the knowledge levels of all who pass here is impossible. If something is being discussed that you don't understand, by all means ask.
C
Chris
Jumpers ...
Add jumper stays (diamonds). While not as flexible as using running backs, it is sure alot simpler. With jumpers, you can adjust them to provide the desired blend of mast bend and/or forestay tension. When you crank on the regular backstay tensioner, then the force will be transmitted more directly to your forestay. Set the jumpers a little loose, and you will flatten the main more before the forestay tension kicks in, and little tight, and you will be forestay tension and less main flattening. Much simpler that having to have another set of line that you have to manage through tacks and gybes. Chris
Jul 11, 2007
34
- - Tampa
I would sail the boat first and see how it does
Alan- Why don't you sail the boat first and see what it needs. I'm sure you probably know this but there are a more fractional rigged racing boats that don't use runners than that do. They adjust the rigs for each race so that they have the proper shroud and headstay tensions for the conditions of the day. If the mast section of the 26.5 is not tapered at the top or is not too soft, a standard backstay adjuster may be all that is necessary. Also, I know you talk a lot about having a tight headstay for pointing, but unless you sail in 10kts and flat water all the time, there are plenty more situations where some (not excessive) headstay sag is very important. With a light boat and a wing keel, it is especially important to be sailing the beats as flat as possible and at max speed. And, on any boat in moderate breezes with a heavier chop, you need the power to get through the waves. So it is better and faster to foot for speed instead of getting those extra degrees of point given these conditions and variables, and that is when your headstay sag equals power. Then when the wind pipes up, you can put on the backstay for the purpose of flattening the sails and bending the mast, so the runners are not really a necessity then. You may find that you don't need them at all. By the way, are you downsizing or just getting another toy?? Just curious.
