Hi All,
I have a Dufour 34 1975.
It never had shore power. I added a box with 30 amps, 3 switches with 2 used for outlets which I custom built somehow. {thanks youtube}
so I was planning to run an electrical wire , 110V , which will go into an outlet on the box, the wire will run in that brown piece
which runs along the boat, let us call it the Electric Conduit. This will go all the way to the V berth where I can put a generic socket.
That brown Electric Conduit thing runs from the back to the front of the boat and has the 12V wiring for lights and similar.
I was told and read one should not run 110V wire near 12V wire.
I still want to do this, so my questions are.
1. Should I do this ?
2. Do I need to use a conduit inside the brown one and if so which conduit type would you recommend ?
Thank you
Electricity and plumbing are not my strong suit.
Thank you
