I Worry About
I worry because nowadays engines, in order to be 'green', now duct their crankcase gasses into the air inlet filter, albeit through a nominal pressure relief valve.
To me this means any overfilled engine or one with combustion gasses leaking past its piston rings has the propensity to run on its own engine oil.
Air filters can be rotated and I have set mine up so that, in the case of a runaway, I could put my hand over the air inlet spout - though whether I would dare to do so is doubtful. I think my palm could withstand 15 PSI vacuum over a 1½" diameter.
For Info: My pal was a boat salesman and it was the day of his new customer to accept his new boat.
He had previously just motored the boat to its berth.
He started the engine to demonstrate it and slowly the revs began to increase.
He shut the throttle but the engine speed continued to increase.
He pulled the 'Stop' control without effect.
He put it into gear but the revs continued to build. They reached 4000 RPM.
He went below and operated the 'Stop' control at the engine, suspecting it might have become disconnected from the wire above. It was connected.
All this took a couple of minutes. The revs kept rising despite being in gear. By now clouds of blue smoke were billowing from the exhaust.
The revs went off the clock, they think to 7,000.
He felt he could do nothing so recommended they both got off the boat - quickly.
He then went in search of the yard's engineer.
Suddenly everything went quiet.
Seized solid.
This all took about 4 minutes - so, if it happens to you, there is time to react - provided you realize that it is happening and act immediately.
Not exactly a good start for a brand new boat!
A new engine was supplied to replace the previous one.
The subsequent post-mortem revealed the sump had been considerably over-filled with oil.
