Jim a vessel engaged in fishing..
Jim,As far as I know the USCG makes no distinction between commercial and pleasure fishing. If you know where that is in the Col Regs please point it out to me. They just say "a vessel engaged in fishing" and not a "commercial vessel engaged in fishing". Here is their actual definition of a vessel engaged in fishing:Quote from Col Regs: "The term "vessel engaged in fishing" means any vessel fishing with nets, lines, trawls, or other fishing apparatus which restrict maneuverability, but does not include a vessel fishing with trolling lines or other fishing apparatus which do not restrict maneuverability."So if a recreational boat is fishing with down riggers, or drifting & bottom fishing, with the motor idling, I'd say they still have the right of way regardless of the fact that they're recreational because down riggers or bottom lines certainly restrict maneuverability. They do make clear that trolling does not constitute "stand on" unless it would restrict the maneuverability of the vessel.As for "right of way" here's what the USCG has to say about it:Quote from the Col Regs on "Right of Way":"The International Navigation Rules do not confer upon any vessel the right of way however, certain vessels in sight of each other are responsible to keep out of the way of others. Usually, power-driven vessels are to keep out of the way of a vessel not under command or restricted in her ability to maneuver, sailing vessels or a vessel engaged in fishing. However, some exceptions exist when they themselves are not in command or restricted in her ability to maneuver (Rule 18), overtaking another vessel (Rule 13), are navigating a narrow channel or fairway (Rule 9), and other less explicit circumstances.Navigation Rules should be regarded as a code of conduct and not a bill of rights. They do not bestow rights or privileges, but impose the duty to either give-way or stand-on, dependent on the circumstances. What is important is not so much what things are, i.e. sailing vessel, operational, etc., but how to avoid collisions, e.g. although under sail yet able to be propelled by machinery, obtaining an early warning by radar, etc. Understand, the Rules are in place to prevent collisions not to define nautical terms or to be subjected to strict interpretation."
