Unbolt the tiller bracket and remove. Underneath, the tiller head is secured
by a large allen head bolt, remove it. On the aft end of the tiller head
there is a tapered pin which goes through the tiller head and the the tiller
shaft, use a hammer and a punch to remove it. Sorry but I can't recall which
side is the smaller on the pin. Of course the small end of the pin is the
side you want to tap on with the hammer and punch. the rudder shoe is
through bolted with 14mm bolts. Remove them and the shoe and rudder assembly
will come off. You will ned to have a couple of feet of clearance between
the keel and the ground to get it completely out of the rudder tube. Good
luck.
Walt
