J.T.Ellis
Back in the fall, on a beautiful sailing day, we were in the middle of a tack when our novice helmsman asked "What do I do now?". When I turned around he was handing me the tiller - which was no longer attached to the rudder.It seems the pin that attaches the tiller to the rudder (I'll call it the pivot pin) had torn a chunk out of the top of the rudder. Looking closely it appears to be a manufacturing defect because there's a large void drilled out of the foam core that was then glassed over. Although at 18 years old, I'd say it lasted pretty well.We've spent the winter dealing with it the best we could and trying to figure out the right fix. Dealing with it the best we could includes dropping the tiller overboard one night as we were anchoring. So, we no longer have the metal cap that fits over the rudder either, as it was still firmly attached to the tiller.Anyway, the solution we've come up with is to trim off the portion of the rudder where the pivot pin ripped through (about a 2"X2" square on the top of the rudder), reglass it, and drill a new hole. This effectively moves the pivot point about 2" forward of the original position. I don't see any reason this would have any noticable effect on the handling.So, 2 questions: 1) Does anyone see a problem with our solution? 2) Does anyone know where we can find that metal cap that screws into the tiller and fits over the top of the rudder? Also, more out of curiosity since I think we're on our way to having this solved, if I needed to buy a rudder/tiller assembly for an '86 25.5, where would I look?Thanks for your suggestions,J.T.
