I have a 1980 Catalina 30.
I have to remove the rudder to repair the rudder shaft using the west epoxy system.
The keel is about 6-8 inches off the ground, does any one know if the boat is high enough off the ground to drop the rudder without digging a hole?
Unfortunately it's sitting on cement so I would have to raise the boat. Any help would be appreciated. Brian
