Rudder Removal 1990 30T
mhogan
Oct 23, 2005
1
- - New Brunswick
This past summer I purchased a 1990 30T Hunter. The boat is now sitting on it's cradle at the club and I need to remove the rudder. I have dug a hole to ensure adequate clearance to drop the rudder and have blocked the rudder. I have removed the steering quadrant (two halves and bolt through). After the removal of these items I thought the rudder would simply drop out. I am able to lift the rudder ~ 1 - 2 in. however the shaft will not pass through a plastic collar that is located just under the steering quadrant. There are no obvious set screws/snap rings etc. Can anyone provide some guidance on what I am missing and where I go from here and if there are any other surprises/hang-ups I should know about?? There are no yard mechanics in my area. Your help would be very much appreciated. Thanks Mike
Mike Jaeger
Call Hunter Marine Customer Service
Give Hunter Marine Customer Service a call. 1-800-771-5556, 8:00-5:00 EST. You may have to leave a message, but every time I've called them someone always calls me back the same day. You'll find them very helpfull. Let me know how you made out.
Mike
Got It!
Thanks for the contact Mike, but I got the rudder out yesterday. It was a frosty morning here and I woke up early grapped by wife's hair dryer and set it up against the HDPE collar and started to gently tap the post with a rubber mallet and out she dropped.
