G
Gary
I have the rudder off our boat for sanding and painting. There is quite a bit of wear to the hole where the bolt goes through. (this of course is the bolt which attaches the rudder to the metal housing) This is allowing some "slap" which is not critical nor dangerous, but if allowed to continue will cause considerable damage to the rudder. Have any of you dealt with this problem, and if so how did you fix it??Thanx in advance,Gary
