rUDDER PLATES
RICK,I RE-WORKED MY RUDDER LASTR YEAR. I FOUND THE SCREWS HOLDING THE SIDE PLATES TO BE VERY CORRODED(DIS-SIMILAR METALS). I WOUND UP DRILLING THE SCREW HEADS OUT, BUT FOUND THE DRILL WALKING OFF THE S.S SCREWW AND INTO THE ALUMINIUM. WHAT I DID WAS TO HAVE NEW SIDE PLATES MADE AND I DRILLED THRU THE SIDE PLATES AND CENTER CASTING WITH THRU HOLES. I THEN USED NUTS, BOLTS AND WASHERS. THE CENTER LOCKING HUBS ARE MOST LIKELY FROZEN AND A FEW WACKS WITH A BIG HAMMER SHOULD DO IT.GOOD LUCK
