The most common complaint that I have heard about is rudder wobble which is corrected by dropping the rudder and wrapping sheet teflon around the shaft. Not to be done while in the water.I have not heard of any problems with splits or anything else.The tiller is another problem altogether as it tends to sweep the cockpit area clean of people.
Pull down the forum menu at the left end of the blue bar on the top of the home page (and many others).Select "Forum Archives"In the Search form that comes up:Enter "rudder"Select "25"Leave it at "All Forums"Select "Original Post"Select "Title" and "Message"Select "Match any Word"Select sort by "Date"Then hit search. That will give you about all we have said about h25 rudders. The other source is the owner reviews on the h25 page.Did you do any sailing last week-end?DavidLady Lillie
can't imagine what the issue would be. pole on a bearing through a hole in the hull;rudder set on the pole. they really aren't complex....... . what could be the problem? regards, jim
