L
Lee
Like on an earlier post, my rudder twists and wobbles too. I drilled out the sleeve that the bolt goes through and replaced it with a nylon insert. I also put JB Weld around the sleeve. I put the upper part and lower together again. (I have he 3 inch nylon washer in place). Tighten the nuts so that the rudder will just come up when I loosen the rope. To my frustration, the thing still wobbles and twists. I thought about replacing the nylon washers with stiffer ones. I can't find heavier 3 inch nylon washers. I also thought about putting a second sleeve in another spot and tighten the orginal and new bolts down so that the rudder won't come up. I would like to hear any other ideas. This has become a pain in the butt for me!
