Rudder hinge ...
Julie,More than you want to know-The hinge pin is at the bottom of the large AL box structure (orginally painted black) attached to the transom. Semi useless Rudder info-(previous owners of my 23 never through anything away)Rudder was made by Foss Form, Inc.Phone (12yrs old)813-577-0478Clearwater, FloridaConstruction is F/G shell filled with Urethane plastic.Surface repairs-clean, dry, rough up damaged area, apply bondo with putty knife. Once patch has dried, sand smooth and paint directly with bottom paint.You will need to pull your rudder. If it's not floating up as it should, something's wrong. To pull the rudder remove the cotter pin or ring from the top hinge post on the transom under the tiller. If it's water logged, it's going to weigh a ton so get help. If its just damaged help's still a good idea because it's no light weight either way.From there drag it home and decide if its full of water or broken (or both probably). If it waterlogged, you can drill small holes to allow it to drain and dry. After that, find the leak(s), patch the holes, repaint and go. If it damaged, let me know how and we can go from there.Gstebbins@aol.comGreg Stebbinsps If you're in Florida (Palm Harbour?)I'm in Tx myself) you could contact Foss Form, Inc..They may offer advise on repairs. If you ask about replacement cost, be sitting down. Rudders are pricey (O-Boy!)
