Rudder post/tiller head shear pin
Oct 30, 2019
119
The pin sheared when the yard launched the boat and I am having a terrible
time getting the broken pin out. I don't know which end to put the punch to
and I can hardly see if the broken pin if lined up. Any suggestions? Should
I drill it?
Nicholas H. Walsh
Admiralty and maritime law; Commercial law
Nicholas H. Walsh P.A.
120 Exchange Street
P.O. Box 7206
Portland Maine 04112-7206
Phone: 207/772-2191
Fax: 207/774-3940
This email is from a law firm and may contain information that is privileged
and confidential. If you suspect you received it in error, please delete the
email and contact us.
[Non-text portions of this message have been removed]
Jan 31, 2009
122
The pin is tapered and drilling out is a very tricky operation given the location. An extractor is the best option, a recent broken pin in a UK boat came out relatively easy with an extractor.
My boat is on a drying mooring and great stress comes on the rudder twice a day. Last time I fitted a pin (about ten years ago) it lasted less than two weeks before breaking since then I have managed without one.
I put a mark on the rudder shaft so I know if the rudder is fore and aft and simply tighten the head up on the shaft with an allen key.
Mike
Oct 19, 2019
921
Albin Vega 27 Limerick
I had the same problem a few years ago.
As far as I can remember, once the pinch bolt was loose it was easy to tap the broken pieces out with a punch.
My visual memory is that the thick end was to port side but I'm not sure...
I started a thread back on the topic then that prompted some very useful replies.
Good luck.
John
Oct 30, 2019
1,459
I ended up drilling it. New 5/32 inch cobalt drill bit, stopped often to put
in a bit of oil, and took it easy. Not too bad a job but I don't want to
repeat it. I marked the side of the fitting where the thicker end is, so
next time there will be no doubt as to which end to put the punch to. And I
lightly notched the top of the rudder post and the bronze fitting so I will
know when it is lined up.
I have sailed with just the clamp holding the rudder post but I like knowing
that connection is really solid.
Nicholas H. Walsh
120 Exchange Street
P.O. Box 7206
Phone: 207/772-2191
Fax: 207/774-3940
From: AlbinVega@yahoogroups.com [mailto:AlbinVega@yahoogroups.com] On Behalf
Of John.Kinsella
Sent: Tuesday, July 23, 2013 3:57 AM
To: AlbinVega@yahoogroups.com
Subject: RE: [AlbinVega] Rudder post/tiller head shear pin
replies.
Good luck.
John
Jul 5, 2006
49
Nico,
Don't forget that you must first ream the hole remaining with a Tapered Pin Reamer to restore the tapered fit and then your "big end" thought will certainly work better when you install the new tapered pin.
Bill McCourt
Reston, VA
May 30, 2006
1,075
Hi all,
Came across these old notes I made some time ago. FYI
-THERMOSTAT / COOLING:
-The MD6A manual states.. starts opening at 75C, fully open at 85C.
-The MD7A manual states.. starts opening at 60C, fully open at 74C. Bellows Thermostat.
-When in the marketplace, looking up the MD6A, shows a 60C thermostat.
-STANT: We do not have a 13980 part number. We have a few stats that are 54mm, 2.125" in diameter and 160F. 13396 is a by-pass thermostat. 13356 and 45356are not by-pass stats. I hope this was some help Chris HoffmanStant Inc.choffman@...
A Stant 160F stat starts to open at 160F (+/- 3) and is full open at 175-180F.
-Volvo p/n: 875796(-5?). 60C. Also maybe 833366, 829812
-Sierra p/n 18-3665. 60C.
-Stant. Lou. 410-446-0063
-also finding a ORB15796 part number.
-The original appears to be a non-bypass unit. and from the pdf exploded views, appears to mount with the sping side into the exhaust manifold.
-WATER PUMP / COOLING
-Impeller is Nitrile Rubber
-Part Number: 3586494, IMPELLER KIT (Volvo Penta)
Price: $ 22.87 Weight: 0.62
-Johnson Pumps of America, Inc. 1625 Hunter Road, Suite B,
Hanover Park, Illinois 60133 Phone 847-671-7867 Greg Nancyx16
-Johnson numbers. Description F35B-9. Volvo 807368= Johnson 10-21934-1 OBSOLETE
Volvo 833415= Johnson 10-32280-1 OBSOLETE by Johnson = Johnson 10-35157-6
-The original pump Model 11260-2101 was fitted to the Volvo Model MD6A.
This was then changed to Model 29300-2201C. My suggestion to obtain this
pump would be to first try Depco Pumps - 1-800-446-1656. Depco maybe able
to assist you with this pump, if not you will have to contact Volvo
directly. David J. Caldwell, Prod Manager, ITT Flow Control (Jabsco).
Office (978) 282-5271 Cell (978) 290-9677
*-Depco. George quoted $235 for new Johnson pump. 10-35157-6(5?), Type F35B-9
This is the latest part and is not same as original. Needs two wing things
to mount on the MD6A. Cost about $10ea. 01-43238. 800-446-1656 ORDERED 9/08
-Rose Marine 877-283-3334 Marty Given this contact by Nancy
-JD at marinepartsexpress. 877-621-2628Sent from my iPad
May 30, 2006
1,075
-Fuel filter: Volvo Penta #3588378 (gotten from Cobe Marine) 10micron?
In victors box..volvo #838593-2 (or ..2-2?)
-Wix #33472 10micron
Equvalent to wix.. NAPA#3472/WIX#33472/FRAM#P8043/ .. Crosses to Sierra 18-7940
Napa#3358 same as above but w no little bleed valve.. cheaper.
-From Volvo: The current part number for the fuel filter is 840531, 2 microns.
-John Kinsella..Bosch 1 457 434 106 to replace a Fleetguard FF5135 fine filter
-Wix Filters, Wix Corp, Gastonia, NC 28052
-Mallory Fuel Filter 9-37906
Replaces Original Equipment Manufacturer(OEM):Volvo MD6A
Replaces Original Equipment Manufacturer # (OEM #):3588378, 860874
This has the little gasket and a bottom bleed valve.
-Mallory Fuel Filter 9-37905
Replaces Original Equipment Manufacturer # (OEM #):3825133
This has the little gasket and no bleed valve.
-Volvo 829913 found this number on vega forum
-Bosch 1457434051 found this number on vega forum
-West Marine cross reference book for the MD6A...
834337-8 PH3614 oil filter..
829993-5 PT510
838593-2 P8043
860874-7 P8043
870065-0 C7521
-Fuel pump, electric:
-Fuel pump p/n E84389 Airtex. Cobe Marine. (installed $150, fits existing bracket)
-found on boat: Harting PU142231 12volts 101, 11AV1155
-Vee belt label on boat: (for starter i think) Goodyear 15461
-OIL / OIL FILTER
-Fram PH3682 on boat
-SAE 30, Svc DS (for Diesel). 4 qts. (don\'t know where this info came from)
-Lubricating system Engine: from MD6A engine handbook
Oil capacity excl. filter 2.8 litres (2.5 Imp.qts.=2.9 US qts.)
Oil capacity incl. filter 3.0 litres (2.6 lmp.qts.=3.2 US qts.)
-From Volvo:The current part number for the oil filter is 834337. Spare oil
filter in boat: Fram PH3682.
-Purchased a gallon of amsoil SAE30W for diesel engines.
Referral Number:1288464 for Hobbie Guyz, LLC Carrol Isl shppg ctr
My cust no. 1674795. Order no. 11974883
-In 2009 I bought directly from the amsoil website, 1 gal.
Synthetic SAE 10W-30/SAE 30 Heavy-Duty Motor Oil, Product Code: ACD1G-EA
From email Vega group: assuming you\'ve got the stub adaptor fitted to the engine as noted by Steve B, I can report that all of the following list of Oil Filters fit the MD6A – Mann W77, Champion C 116, Crossland 659.Framm PH2874 (They\'re all for Renault 4 or 1.1 litre Renault 5 cars).
For future reference, suitable diesel filters are Crossland 658 or Framm P5770
-STARTER, GENERATOR, ALTERNATOR, DYNASTART
-Mike at go2marine. mikew@... 800-998-9508 send pics.
-http://www.woodauto.com/component.aspx?ref=DST10001 replacement dynastart
OEM OEM Reference No.
BOSCH 0010300006
BOSCH 0010300100
BOSCH 0010350004
BOSCH 0010350101
DELCO/FORD 19025600
EFEL 06000
EFEL 6000
KHD 1162558
VOLVO 803499
VOLVO 834692
Wood Auto Supplies Ltd DST10001
