G
Gary Ross
I have found that my rudder has 1-2" of vertical movement observed with the boat out of the water. Both the rudder and the shaft move together. I suspect it is the result of a worn bearing. 1. Could the movement be caused by anything else? 2. If it is the bearing, where is it and how does one get it out for replacement?Information will be greatly appreciated.Gary
