John Powell
I recently bought a 1993 Hunter 23.5. I park it in a dry slip with the mast up. Nearby is another 23.5 which has a different rudder. Both look the same but the difference is in the hole through the rudder where the line is tied to drop the rudder or haul it up.On my boat, there is only one hole in the rudder and that is from side to side. The other boat has this hole and also a smaller diameter hole running from the edge of the rudder through to the larger hole (which is side to side).The result is that the other boat's line is tied in with a stopper knot and runs up through the steel rudder holder (sorry, my terminology for this part escaper me.)Is there any reason I should not drill a small hole in my rudder and rig the line in the same manner as the other boat. My guess is that my boat is an early version and the other boat has a newer style rudder. The 240's at a nearby dealership have the same arrangement as the other 23.5.thanks. John Powell
