Tom Grass
In my previous post I alluded to the broaching problem I had in a recent race in very high winds (gusting to 35 MPH). The general opinion of this forum was that it was primarily due to my rudder riding up; a conclusion I agree with.Now - short of replacing the rudder (always plan 'B') - what are the suggested solutions to this problem?I plan on replacing the hold down lines on the rudder (but do these lines, even when cleated on the tiller - really hold the rudder down???).One other solution I'm contemplating - one that I did successfully on my Catalina 22 ... (this solution came to me from Catalina Direct) ...The solution consisted of drilling two holes through the metal casting at the top of the rudder ... then indenting slightly the rudder directly beneath the drilled holes (when the rudder is in the full down position). Next disassemble the rudder and insert a pop rivet into the drilled hole in the casting - with the rivet head resting between the rudder and the casting. When you lower the rudder - the rivet heads fit into the indentation you made - and hold the rudder in place ... if you hit something - the rivet heads will slide between the rudder and casting. This solution did work on my Catalina 22. What about a Hunter 26?Any other ideas?Thanks all.Tom GrassGrasshopper II1994 H-26 # 174
