Rudder Maintenance
50
Oday 28 ft Jamestown
Greetings: Here's my problem. When I am on the mooring at night with the tiller locked in the midships position, it seems to clunk ever so slightly. Now she is on the hard, and before I do any drastic digging to drop the rudder down, I was wondering if I am missing some maintenance issue here? Climbing in the battery compartment, I see a grease fitting on the rudder tube. What kind of grease does it take and how much? And does anyone think this would help? Thank You for any help you send my way.
Jun 28, 2009
104
1984 O'Day 28 Bath, NC
Hello Mick,
I'm sure some grease won't hurt. My 84 O28 has two grease fittings on the rudder tube. One toward the top of the tube the other toward the bottom of the tube. Use a marine grade grease. I ended up pumping quite a bit in, until I seen it coming out the top of the tube.
Mar 7, 2010
50
I'll check the tube top. I only saw one. It sure would be easier than dropping the rudder, I do not think its the bushings. Thank You
Feb 26, 2009
716
Oday 30 Anchor Yacht Club, Bristol PA
see if it's the rudder head Mick. looseness in the through bolt/s pivot...
