I just disassembled the rudder casting to install new CD Locking Discs and found there is no bolt holding it together but instead there is a threaded rod going through the rudder. The rod is secured in place by unknown means or adhesives. Am I correct that it should just be a bolt going through the locking discs and rudder. I will assume I can possibly remove what is holding the rod in place, fill with thicken epoxy and drill for a bolt. I do not know how original the rudder is to my 1976 C22. Thanks as always. Example pictures attached.
