H
Henry Weber
Al--I have a 1977 Hunter 30. I expect to have to replace the bearings on the rudder (starting to have play). The rudder is held in place by a bearing at the top inside the boat and above the water line. There is a skeg in front of the rudder extending to the bottom where there is also a bearing supporting the bottom of the rudder. My question is what is the correct way to remove the rudder ( in water??or not) and where does one buy the bearings? Thanks for your efforts. I imagine that most of us here are interested in this info.Thanks again,Henry -- Boca Raton, FL.
