rudder gasket material
Jul 8, 2015
2
hunter 26 plymouth
Can anyone tell me the name of the red gasket type material that is glued to the insides of the aluminium rudder cheeks used as a friction break.
many thanks dean
BrianW
Jan 7, 2005
843
Hunter 26 Guntersville Lake, (AL)
Red rubber, or styrene butadiene rubber (SBR). It can be bought as sheet stock and cut by using your old gaskets as patterns. I used rubber cement to glue it into the rudder head plates. BrianW
Aug 23, 2013
3
Hunter 146 Marion
I've been in the gasket business for 44 years and I'd be hesitant about using red rubber or SBR rubber in this application; albeit, that is what was used as OEM material. Red rubber is SBR and is susceptible to ozone attack; which is why you need to replace it. EPDM rubber or neoprene have excellent ozone resistance and would be my first choice. They will most probably be black in color. May be obtained at most any local gasket fabricator.
BrianW
Jan 7, 2005
843
Thanks Gasketbob! The water-ballasted boats have about a 6" round plate on the hull's bottom that seals the inlet and drain for the water ballast compartment. My H26 has a red rubber gasket here. While the seal is not perfect, it keeps mass quantities of water from flowing in and out of the ballast tank inlet. Gasketbob, what gasket material would you recommend for this? Thanks, BrianW
Aug 23, 2013
3
Hunter 146 Marion
Brian,
Either the EPDM or the Neoprene that you decide to go with for your rudder brake is acceptable for this service as well. If you're only replacing the "red gasket" on this plate; then, red rubber (SBR) is fine.
Doug J
May 2, 2005
1,192
Hunter 26 Oceanside, CA
I will be replacing the rudder friction gaskets on my H26. Al from the store on this site responded to me with all the parts needed to rebuild the rudder assembly.
Here's the list.
"Most of the parts for the Hunter 26 rudder we can offer for a replacement. Below I have listed the parts that we can offer with costing."
7/8" OD x 17/32 ID x 1.63" Long made with Delrin Rod, Rudder friction bolt bushing, your cost $17.95 each
7/8" OD x 17/32 ID x 1 11/16" Long made with Delrin Rod, Rudder pivot bushing, your cost $17.95 each
1" OD x 13/32 ID x 1 .63" Long made with Delrin Rod, Tiller stop bushing, your cost $17.95 each
2" x 2" X 3" Gudgeon blocks, drilled and radiused to the drawing, Made of UHMW, $65.95 each
Rudder Friction gasket link listed below, Item# 827352 $20.00 each
http://shop.hunterowners.com/hp/part.php?m=26&c=3&p=54733
Rudder Delrin spacer for top of rudder head, Item# 800523 link listed below. $22.95 for a set of 2.
http://shop.hunterowners.com/hp/part.php?m=26&c=3&p=52717
