Rudder Float
E
Eric Nelson
Hello gang! I am looking for anybody who has experience with their rudder rubbing on the hull as it sweeps left and right. I believe that the rudder wants to float and there is nothing to hold the rudderpost from moving up. I can see a nylon bushing that keeps the post from slipping DOWN, but I can also see that the rudder has been rubbing on the hull just above the rudder in the midship position. Any Ideas??
E
Edward Kennedy
Rubing Rudder
I had the same problem. My solution, get a piece of thick plastic approx. 4 inches square. I used 1/2 inth thick nylon, but polyethylene (small plastic kitchen cutting board) would do well. Cut a u shaped hole in it so it fits around the rudder shaft and mount it on the bottom of the upper shelf. The last thing needed is a collar to clamp around the rudder shaft below the plastic board. I bought a large propeller shaft zinc, clamped it around the rudder shaft, and the problem was solved.
J. Tesoriero
My solution
My solution to the rudder "floating" and rubbing against the hull problem, was to make a gasket out of plastic material. I used # 2 plastic from the lid of a large spackle container. I cut a 4-5 inch circle with a center hole the diameter of the rudder shaft. I made a radial cut and by bending the "donut", got the gasket to fit between the top of the rudder and the hull. Each spring before the boat goes in the water, I spread some waterproof grease on both sides of the gasket using a wooden blade. This reduces the friction, makes steering easier and the plastic gasket has lasted five seasons so far.
