Hideho, all!
Last season, I noticed a slight pulsation and cavitation in the rudder, under sail I. Some conditions.
Muskrat love is a wheel steered boat, so I'm assuming that if I can feel it clearly through the " insulation" of the gearing, she's really flapping her wing, so to speak.
It seems as though it's gotten worse, and is very prevalent under power at low speeds. I don't detect any appreciable play in the rudder while she's tied up.
I spent a fortune at the start of last season, to have the motor and shaft re aligned, the stuffing box re packed, etc while she was " on the dry". It could very well be experience and/ or my craziness, but I swear I never noticed it prior to that.
Any thoughts? And are there things that I can/ should do while she's in the water, in a DIY format, that may identify a problem if there is one? She just doesn't "feel right" to me. That said, I've probably got less than 100 hours at the wheel with her, and I may be paranoid. She also seems to want to fall off to port, no matter the point of sail. ..
