Doug Kimbrell
I recently was hauled for a bottom job and found very loose rudder bearings after only 3-1/2 years and only 2,500 miles of total use. The shipyard removed the rudder and bearings and to my dismay the rudder stock had a finish that looked like a file. The surface finish was checked and found to be 175 where as a bearing surface I would expect 32 to 64 RMS max. After several calls to both Hunter and Foss Foam by both myself and Seabrook shipyard, I made my own bearings, and spent considerable time to hand polish the rudder stock to a suitable finish. The boat is fine now but Hunter and Foss refused to help in what was a very definate case of poor quality. The response from Hunter really surprised me. If your 37.5 is a 96 model you may want to look at the rudder for looseness at the next quick haul. But don't look to Hunter for help.
